This page says that I have to edit the "linux" line in the grub boot menu to set up bootchart. I do not understand what exactly it is that I have to do. Please help.
Asked
Active
Viewed 6,600 times
17
You don't need to do that any more in 15.10 or any other Ubuntu release booting with systemd. It automatically records the necessary information on every boot and allows you to analyse it with the command
systemd-analyze
The argument to get a graphical bootchart as SVG image is:
systemd-analyze plot > filename.svg
But it has also other useful commands. You see a list of possible arguments by entering systemd-analyze and pressing Tab twice using the Bash autocompletion, or old-style by opening the manual page with man systemd-analyze or showing the help with systemd-analyze --help.
Here's a list of the commands. Default is time, if you don't specify any other:
Commands:
time Print time spent in the kernel
blame Print list of running units ordered by time to init
critical-chain Print a tree of the time critical chain of units
plot Output SVG graphic showing service initialization
dot Output dependency graph in dot(1) format
set-log-level LEVEL Set logging threshold for systemd
dump Output state serialization of service manager
verify FILE... Check unit files for correctness
Byte Commander
- 110,243
