I am trying to install ubuntu on my computer, which currently has windows 7 on it. The idea is to have both of them as an OS that I can choose from, so I believe that I have correctly partitioned the correct bytes for it. The problem is that when I get to the installation part, after going through the boot setup, I get a strange error.
Something noticeable is...while going through the menus, my Wi-Fi seems to be sort of unstable as after checking the "download updates while installing" and "install this third party software", it disconnects only to reconnect when I go to the next menu. Not sure if this is something to be concerned about but just mentioned it in case this might be another factor.
Now the real problem is on the "installation type" menu. My top option says, "install ubuntu INSIDE windows 7". To my understanding it is supposed to say "install ubuntu ALONGSIDE windows 7". Whenever I do select the option and click continue or install, then it quickly takes me back to the window start up page. And I see no changes at all or no indication that ubuntu was installed.
Any help please as to why I'm not getting the right menu option? Or anyways to work around this?
NOTE I am trying to install Ubuntu and not Windows.
Thank You
Salohcin G
