74
I have to open up a group of ports.
Adding the single ports to (g)ufw was easy enough but I can't work out how to open the range 11200-11299.
How do I do that?
Pieter Breed
  • 1,005
5 Answers5
112
You can specify port ranges to ufw (the command-line one), using : (colon) to separate the lowest and the highest port in the range. For example:
ufw allow 11200:11299/tcp
Note that the protocol part (/tcp or /udp) is mandatory with port ranges.
This works at least since Ubuntu 10.04.
50
Either
ufw allow 11200:11299/udp
or if you need to use a from source ip range you must use full syntax
ufw allow from AAA.BBB.CCC.DDD/EE to any port 11200:11299 proto tcp
ufw allow from AAA.BBB.CCC.DDD/EE to any port 11200:11299 proto udp
see:
https://bugs.launchpad.net/ufw/+bug/1337767
Its worth adding that if you want to restrict to a specific IP address which is allowed access to those ports you can use the following:
ufw allow proto tcp from 1.2.3.4 to any port 40000:40100
Antony
  • 279
I believe you can specify the range in the last tab of new rule, tick the checkbox at the bottom of the window to add more options (just to be safe). The range can be specified as 1000:1010 to open ports 1000-1010.
evgeny
  • 9,865
-3
The cleanest command line way I've seen is a little script like this:
for i in `seq 11200 11299`; do
  ufw allow $i
done
Oli
  • 299,380
