For anyone dealing with the message
WARN: "Invalid ports in profile 'cassandra'"
or just trying to set up Cassandra on UFW in Ubuntu I found the above pa4080 ports= example the only thing I could get to work. Having found that I carefully worked back through it and it seems that for more than one port UFW wants /tcp (or I assume something else equally as valid) on the last port.
[cassandra]
title=cassandra ufw rules
description=cassandra needs these ports to run
ports=22,7000,7001,7199,9042,9142,9160/tcp
I found this to be the complete, acceptable entry for UFW.
Having spent a fair amount of time on reading the documentation I will follow with my notes that may be of interest.
Public port
Port number. Description
22 SSH port
Cassandra inter-node ports
7000 Cassandra inter-node cluster communication.
7001 Cassandra SSL inter-node cluster communication.
7199 Cassandra JMX monitoring port.
Cassandra client ports
9042 Cassandra client port.
9160 Cassandra client port (Thrift).
9142 Default for native_transport_port_ssl, useful when both encrypted and unencrypted connections are required
To do this manually:
sudo ufw allow 22
sudo ufw allow 7001
sudo ufw allow 7199
sudo ufw allow 7000
sudo ufw allow 9042
sudo ufw allow 9160
sudo ufw allow 9142
Ports 7000 and 9042 must be available for external nodes to connect to.
As a security measure, limit connections to these ports to only the IP addresses
of any other nodes in the cluster.
ufw allow proto tcp from [external_node_ip_address] to any port 7000,9042 comment "Cassandra TCP"
Next step is ufw allow from 192.168.0.0/16 to any app cassandra and test that.
