I have installed Ubuntu 14.04.3 to a 16GB pendrive so as to obtain a Live OS that stores persistent data on an ext4 partition. I followed the instructions on various tutorials and answers, recently on this: How do I get a live-USB to use a partition for persistence?
Everything works fine except persistence.
This is what I did:
  1. Boot from a live Ubuntu on USB (here: USB2) without a persistent file.
  2. Insert another USB (here: USB1), open gparted, unmount and delete all partitions.
  3. Select "unallocated" and create two partitions:
    sdc1: 1 - 2170 - auto - MiB // Primary Partition - fat32 - OS
    sdc2: 0 - auto - 0 - MiB // Primary Partition - ext4 - casper-rw
  4. Extract USB1 and then insert it in a Windows machine. Install Ubuntu on OS using "UNETBOOTIN" (but I've also used "Universal USB Installer", no difference later on) and set a 10 MiB persistent file.
  5. Delete casper-rw under Windows (but I've also done it under Ubuntu).
  6. Boot Ubuntu from USB2, insert USB1, open GParted and Right Click on the fat32 partition (OS 2.10 GiB), select Manage Flags and check "Boot" and "lba" ("Boot" is already checked; checking "lba" does not seem to change the situation later on).
    The "casper-rw" is now larger than 4GB (12.81 GiB), but persistence does not work.
  7. Modify the file "txt.cfg" as reported here below.
But even so persistence does not work. Can someone help? Many thanks in advance.
default live
label live
  menu label ^Try Ubuntu without installing
  kernel /casper/vmlinuz.efi
  append  file=/cdrom/preseed/ubuntu.seed boot=casper cdrom-detect/try-usb=true persistent noprompt floppy.allowed_drive_mask=0 ignore_uuid initrd=/casper/initrd.lz quiet splash --
label live-install
  menu label ^Install Ubuntu
  append  file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity cdrom-detect/try-usb=true persistent noprompt floppy.allowed_drive_mask=0 ignore_uuid initrd=/casper/initrd.lz quiet splash --
label check
  menu label ^Check disc for defects
  append  boot=casper integrity-check cdrom-detect/try-usb=true persistent noprompt floppy.allowed_drive_mask=0 ignore_uuid initrd=/casper/initrd.lz quiet splash --
label memtest
  menu label Test ^memory
  kernel /install/mt86plus
label hd
  menu label ^Boot from first hard disk
  localboot 0x80
Syslinux has not allowed persistent partitions on the same drive since Ubuntu 14.04.
However a Syslinux type install, (UNetbootin, Rufus, Universal), will use a persistent partition labeled casper-rw or home-rw if it is located on a different drive, either internal or external. It will use the first casper-rw file or partition it finds while booting
If you want a casper-rw partition on the same drive use grub2 type bootable disk creator like mkusb, (that works with BIOS and UEFI), or install grub2 to the USB manually and loop mount an ISO.
If you simply need more than 4GB persistence you can use YUMI to make the drive, it's casper-rw file can be larger than 4GB and there is a UEFI version.
C.S.Cameron
  • 20,530
  • 78
  • 125
