I'm new to Ubuntu, I install it yesterday and I'm loving the system.
But there is a problem with Nautilus and I have no idea on how to fix this. Nautilus randomly loses its Ambiance theme, becoming all gray with a strange look. The icons also disappear too.
Doing a logoff or rebooting the system fixes the problem, but it happens again after a while. It seems completely random and it's quite annoying.
The Ubuntu version is 11.10 64 bit.
Removed
  • 3,748
It's an annoying bug, reported here (though I'm not 100% sure that this isn't a duplicate of the bug I was looking for).
As a workaround you can run this from a terminal:
killall nautilus ; (nautilus &)
htorque
  • 66,086
If you use nautilus -q command in terminal. it will solve. you just have to do it every time it happens. And open any folder after that command
BuZZ-dEE
  • 14,533
With older versions of Ubuntu, this was typically caused by a crash of gnome-settings-daemon. To fix it, I could press Alt+F2, gnome-settings-daemon, Enter.
I'd like to know if this workaround still works in Ubuntu 11.10. (So far I haven't seen this happen to me.)
