I have Ubuntu in dual boot alongside the original W8 install. My grub shows a ton of options. The first one loads Ubuntu alright. In the past I tried loading w8 (which I hardly ever use) and after loading W8 and restating the machine it somehow managed to get grub disabled. Which option loads W8, and is there a way to clean up grub to show only relevant options?
To boot Windows 8, you need to select
Windows 8 (loader) (on /dev/sda4)
I understand that you want to tidy up the menu. This can be done most easily with the program grub-customizer. It's available from ppa:danielrichter2007/grub-customizer Launchpad logo (Click here for instructions on using PPAs.)
So to install it on your Ubuntu system, run the following commands:
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
Then, launch grub-customizer. After it has loaded your configuration and detected all locally installed bootable stuff, you should see a list like this:
grub-customizer screenshot
You can rename items by double-clicking them.
To create submenus (folders) to group several similar menu points to one entry, select all items you want to group and chose Create submenu from the right-click context menu or the Edit menu.
Changes will not be applied until you click the Save button, or close the window and chose Save & Exit from the appearing dialogue.
Byte Commander
  • 110,243
