please I am new in this Forum and in this, I want to download the Ubuntu OS and change the Windows starter I already have in the Dell laptop. Is it that possible? How can I do it? Any help? Please Really appreciate.
Try looking here:
http://www.ubuntu.com/download/desktop
After you download it, insert a blank DVD into your computer. Choose to do nothing when the AutoPlay (or similar) dialog pops up. Right click the .iso file and choose "Burn to disk". (That should be close to the actual wording.) Once that is done, put/keep the disk in and restart your computer. After that, go here and follow the instructions: http://www.ubuntu.com/download/desktop/install-ubuntu-desktop
- 121
Yes it is possible. You need to first download the iso file, then the easiest way for beginner in my opinion is to burn that Ubuntu iso file to a DVD. (make sure your system architecture is the same as the iso. eg. If your machine is 64bit, then download the 64bit Ubuntu and so on). Once you have done that, you have to insert the disk, restart your computer, and go onto your BIOS setting (spamming F2 on my dell laptop while it's booting up, yours might be F12, F10, or F8 depending on your machine). Go to a boot device sequence settings and you should change the boot priority to your DVD/USB that you have burn your iso file into. From there, it will start booting from that device, and will ask if you want to install Ubuntu to replace the OS, or install it side by side (dual booting). I have mine dual booted, so I can switch around between Ubuntu and Windows. From there, the rest of the installation process is pretty much self-explanatory. Partitioning, settings, etc. Good luck, and if you have any questions or my instruction is unclear, just reply. (I'm rushing this answer)
- 1
First download ubuntu os 64 bit or 32 bit depending on your computer.Then you need to make a bootable usb/cd drive,you can easily do that with http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/. Then reboot your system with your usb/cd in and press F12.In BIOS menu select BOOT--->Hard Disk Drives.Next follow the installation of ubuntu ;)
- 81
