my vm is centos 4.8 and it came from a physical server. All is great except I can't seem to get bridged networking working. The default user mode networking is fine, from the guest I can reach the internet but I want to bridge so the host can see the guest.
I've read some docs about it but it feels like I'm missing the big picture and am getting confused. Am I setting up the bridge network interface on the host? And what role does the config files in /etc/libvirt play? I see that when I use the virtual machine manager, it adds xml files there but what about the network interface stuff. Is that modifying the host system when the libvirt service starts?
The bridge network interface is setup on the host computer. When you use bridging the guest network interface uses the host bride interface. The .xml files in /etc/libvirt/qemu define the VM, and therefore play an all important role. If you are using bridging, there should be lines similar to:
<interface type='bridge'>
  <mac address='52:54:00:87:d2:f4'/>
  <source bridge='br0'/>
  <model type='virtio'/>
  <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/>
</interface>
I do not use virt manager, but this and this might help you.
Doug Smythies
  • 16,146
