I'm trying to install KVM. I've done the installation and I'm now following the second part of the guide to get bridged networking to work. However, I'm stuck at the part where I need to modify the /etc/network/interfaces file.
(Note: I don't have X installed.)
I'm on Ubuntu Server 15.04:
$ uname -a
Linux boson 3.19.0-21-generic #21-Ubuntu SMP Sun Jun 14 18:31:11 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
$ ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:72 errors:0 dropped:0 overruns:0 frame:0
          TX packets:72 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:11098 (11.0 KB)  TX bytes:11098 (11.0 KB)
p17p1     Link encap:Ethernet  HWaddr bc:5f:f4:ea:0e:28
          inet addr:10.0.1.220  Bcast:10.0.1.255  Mask:255.255.255.0
          inet6 addr: fe80::be5f:f4ff:feea:e28/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:173566 errors:0 dropped:0 overruns:0 frame:0
          TX packets:219213 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:18152992 (18.1 MB)  TX bytes:208778324 (208.7 MB)
          Interrupt:16
virbr0    Link encap:Ethernet  HWaddr 52:54:00:82:25:dd
          inet addr:192.168.122.1  Bcast:192.168.122.255  Mask:255.255.255.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
The file currently looks like this:
$ cat /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto p17p1
iface p17p1 inet dhcp
#auto virbr0
#iface virbr0 inet dhcp
#        bridge_ports p17p1
#        bridge_stp off
#        bridge_fd 0
#        bridge_maxwait 0
If I uncomment those last lines and do systemctl restart networking the network connection on p17p1 is lost. ifconfig then shows that both p17p1 and virbr0 have the same IP-address.
Should I use the static settings instead?
Mausy5043
  • 760
You should not need to use static settings instead.
Also, I see that you have already found this answer
For a dynamic IP address solution, you should set up a real bridge and use it. Your interfaces file should become:
auto lo
auto br0
iface br0 inet dhcp
   bridge_ports p17p1
   bridge_fd 9
   bridge_hello 2
   bridge_maxage 12
   bridge_stp off
Note: I got some of the settings from the Ubuntu server guide
Doug Smythies
  • 16,146
