Possible Duplicate:
How do I install and use the latest version of GNOME 3?
How to revert to GNOME Classic?
im noob in linux, and recently i have installed ubuntu 11.10 but i've always work on gnome environment, i really want the gnome environment. Someone knows a reliable method to change unity to gnome
If you're going for gnome2 then all you need to do is click on your username at login, at the bottom of the screen you'll see Ubuntu in a drop-box. Change it to Ubuntu Classic.
-1
Ubuntu 11.10 no longer includes Gnome 2. Gnome 3 is included, but it is rather different from Gnome 2. Although there are ways to install Gnome 2, I doubt you can achieve good system stability with them, given that Unity runs atop Gnome 3, and Gnome 2 is no longer maintained. You can install Xfce, however. Enter this command in the terminal and then enter your password when prompted.
sudo apt-get install xubuntu-desktop
Xfce is different from Gnome 2 in some ways, but it is closer to Gnome 2 than anything that you can easily install. Click the gear next to your username when logging in, and select the Xfce option.
Kevin
  • 319
