I want to run a development environment of Ubuntu on my Windows 10 machine, since I'm just using it for coding I thought I'd just download xubuntu since I only really need a lightweight OS to run on a virtual machine.
I've got xubuntu running on my VirtualBox but the screen resolution is locked at 640x480 without any options to change it to be a higher resolution. I can't handle coding on such a tiny resolution, is there anyway I can change the resolution a more reasonable resolution?
My xubuntu version is: xubunut-14.04.3 Host machine: Windows 10
You have to install the virtualbox guest additions. They change the resolution, enable drag and drop, and some more.
You can read it here:
How do I install Guest Additions in a VirtualBox VM?
Now, the resolution will change according to your virtualbox window.
davidbaumann
  • 1,915
you should use Guest box additions.
more info on how to do this :
http://askubuntu.com/questions/22743/how-do-i-install-guest-additions-in-a-virtualbox-vm
Thanks
