Possible Duplicate:
How to customize live Ubuntu CD?
Change the min_disk_size answer to Why does the Lubuntu minimum install say that it requires 10.7 GB of available drive space? describes:
In LiveCD environment...
Is it also possible to delete items from the application to be installed from the LiveCD environment? How?
W.,
as described in your link this is a suggestion.
Using an alternate CD you can instal a minimal system even without window manager and then install only the applications you really need.
Greetings from Switzerland, Michael
Michael K
  • 14,338
Try Lubuntu Slim 10.04 LTS from http://ubuntu-fr.org.
Eliah Kagan
  • 119,640
zillion
  • 291
You can't remove items which have to be installed on startup from a Canonical supplied CD/DVD/USB Stick but if u want, u can create a Customised Live CD if u want, here is the link:
https://help.ubuntu.com/community/LiveCDCustomization
Or if you want to install the packages by yourself, you could try Ubuntu Server:
http://www.ubuntu.com/download/server/download
