I have setup my computer to have a dual boot for Ubuntu and Windows 10. The installation process worked fine, so both are operational, however, I do not have the option to choose one or the other when booting.
In the BIOS settings, when I have Ubuntu as a low priority, Windows will boot immediately with no option for anything else.
When I have Ubuntu as the highest priority, it will go to an options page, but none of these options will go to Windows (as far as I know). These options are
  • Ubuntu
  • Advanced options for Ubuntu
  • Windows Boot Manager
  • System Setup
At the moment, I have Ubuntu as low priority, so when I boot, it loads Windows. Then I restart the computer with
Advanced Restart Options -> Use a device -> Ubuntu
I would like to have the option to choose between Windows or Ubuntu at startup, and I am not sure how to do this.
mojo1mojo2
  • 103
There may have been some error with your grub. It is possible that that grub did not correctly configure itself to link to windows boot manager. To rectify this problem
  • Open a terminal (Ctrl+Alt+T).
  • Run boot repair. This will automatically detect window boot manager and correct the links.
To install Boot Repair
  • Connect to the internet, Open Terminal and run the following command
sudo add-apt-repository -y ppa:yannubuntu/boot-repair; \ sudo sh -c "sed -i 's/trusty/saucy/g' /etc/apt/sources.list.d/yannubuntu-boot-repair-trusty.list" \ sudo apt-get update; \ sudo apt-get install -y boot-repair && boot-repair
Note: You can copy and run them all at once. If you want to run them individually just remove the trailing "; \".
And if you have to make any further changes to grub, then after you have logged into your system
  • Type in the terminal gksu gedit /etc/default/grub
  • To see the grub-menu at boot time, comment or remove the following line: GRUB_HIDDEN_TIMEOUT=0
  • To comment, add # at the beginning of this line, the result will be #GRUB_HIDDEN_TIMEOUT=0
  • Save the file.
  • In the terminal run sudo update-grub.
Other Sources: How to install the Boot-Repair
Ayushya
  • 241
From OP description firmware is UEFI.
  1. "Windows Boot Manager" entry in GRUB menu is the answer.
In Windows Vista to Windows 10 it is Windows Boot Manager which controls Windows boot selection (or loads Windows directly if only one boot entry).
  1. You can use one time boot selection key (usually F12, could be other on your system) to switch between Windows and Ubuntu.
  2. You can install "rEFInd" boot manager to display a boot menu for all installed OS like Windows and Linux descendants.
snayob
  • 447
