I have installed Ubuntu 10.10 and it does not work, it hasn't worked since the beta I believe, any ideas? By the way this is a clean install, and it does not work on my older install either.
Marco Ceppi
  • 48,827
TheXed
  • 27,638
6 Answers6
As mentioned, this is a bug: https://bugs.edge.launchpad.net/ubuntu/+source/gwibber/+bug/614742
According to a Gwibber developer, the problem actually lays with the Facebook API:
Since Gwibber was included by default in Ubuntu, usage has gone way up and we quickly exceeded our API request allocation with Facebook. Facebook allocations are per application, not per user, which means Facebook blocks API requests for everyone, not just the users which are refreshing too often, etc.
http://blogs.gnome.org/kenvandine/2010/10/19/gwibber-and-facebook-call-for-help/
This worked for me, thanks to this user on Ubuntu Forums. http://ubuntuforums.org/showpost.php?p=9980897&postcount=15
Go to your home folder and show hidden files, open .config/gwibber/ and delete gwibber.sqlite.
NightwishFan
  • 3,736
I found that deleting the gwibber.sqlite as suggested didn't work for me. What did was removing :
.gconf/apps/gwibber/preferences/%gconf.xml
This was under the user profile. Soon as I did this it worked find and the size of the newly created xml file jumped up by 6 times the amount.
Seth
  • 59,332
The latest Gwibber updates fixes the issue. Gwibber showing feeds now. Thought of updating here. :)
user227495
  • 4,309
Login to your facebook account and click: Account > Application Settings. Remove the link to gwibber by clicking the X on the right hand side. Go back into gwibber and try adding your account again.
unfortunately, because of the bug Mike has written about, the only solution that works now is trying to remove/add account many times :(
I tried about 35 times, and finally it worked...
Praweł
  • 6,536
