13
in order to fix a problem with the setup of the screen brightness I try to create a xorg.conf
This is done by the command X -configure right?
Trying to run this command as root, I will get:
Fatal server error:
Server is already active for display 0
    If this server is no longer running, remove /tmp/.X0-lock
    and start again.
Trying to run this command in recovery modus, I will get the same. After remove the mentioned file I get the error: cannot create file /tmp/.X0-lock Just to make sure: Yep I have the rights as I am logged in as root.
Jorge Castro
  • 73,717
bios
  • 261
I think you shall have to stop the xserver first. Try this:
  1. Open a Terminal with CTRL+ALT+F1 and login
  2. sudo stop lightdm (or kdm or gdm instead of lightdm if you installed kubuntu or GNOME shell)
  3. sudo Xorg -configure
  4. sudo start lightdm (or kdm or gdm instead of lightdm if you installed kubuntu or GNOME shell)
gman
  • 2,324
Ralf
  • 81
run ps auxw |grep X
and kill the process
then run again.
refer:http://git.net/ml/apple.fink.beginners/2002-08/msg00246.html
