I'm running Ubuntu 12.04. Earlier today I launched startx and got a blank wallpaper-like screen with nothing on there. I thought maybe it was taking time to load but it would just remain stuck there. Looking for a way to get back to the command prompt, I pressed Ctrl+Alt+F6 and got back to the command prompt. Later today, I tried launching startx again and got this error:
Fatal server error:
Server is already active for display 0
    If this server is no longer running, remove /tmp/.X0-lock
    and start again.
Please consult the The X.Org Foundation support
    at http://wiki.x.org
for help.
ddxSigGiveUp: Closing log
Invalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyxinit: giving up
xinit: unable to connect to X server: Resource temporarily unavailable
xinit: server error
Someone here suggested to type in sudo stop lightdm and someone else over here suggests to type sudo service lightdm stop, however both give me the following message:
stop: Unknown instance:
I tried killall X which gives me:
X: no process found
I'm not so sure about deleting /tmp/.X0-lock because the first link up there says that deleting it just gives you the error message cannot create file /tmp/.X0-lock instead. By the way cat /tmp/.X0-lock gives me:
    14275
but that process doesn't seem to show up in top, although it may be way at the bottom, I'm not sure how to scroll down.
What should I try next?
biohazard
  • 143
