I faced the problem of installing the software. It was stated something about unmet depedencies with the bitdefender-scanner:i386 package (its antivirus that I was trying to install the day before but something went wrong and it wasn't installed at all) And now I'm getting errors while instalation of other software.
Here is what I get in the terminal when im trying to delete this damn package:
sudo apt-get -f install
[sudo] password for beast:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 3 not upgraded.
1 not fully installed or removed.
After this operation, 141 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 251963 files and directories currently installed.)
Removing bitdefender-scanner (7.7.1-1809) ...
find: `/opt/BitDefender-scanner/share/locale': No such file or directory
dpkg: error processing package bitdefender-scanner (--remove):
subprocess installed post-removal script returned error exit status 1
bitdefender-scanner
I've tried all from this post: link but it didn't help. I still cannot install software due to this problem. My OS: 14.04lts,x64
Please assist and advise how to prevent it in future. Thank you:)
Taras_G
Edit the post-removal script
sudo nano /var/lib/dpkg/info/bitdefender-scanner.postrm
and delete the line
set -e
But be in mind, that's only a good idea, if you have to force the removal of a package.
The package management system looks at the exit status from these scripts. It is important that they exit with a non-zero status if there is an error, so that the package management system can stop its processing. For shell scripts this means that you almost alwaysneed to use set -e (this is usually true when writing shell scripts, in fact). It is also important, of course, that they exit with a zero status if everything went well.
Finally, remove the package again
sudo apt-get purge bitdefender-scanner
sudo apt-get autoremove bitdefender-scanner
A.B.
  • 92,125
