11
Problems:
1) Power management makes Wifi connection unstable. I need to disable it completely
2) My wifi doesn't automatically turns on after sleep. I should do it myself
Info
Laptop: Dell vostro 14-5480
OS: Ubuntu 15.04
kernel: 3.19.0-30
Wifi-card: Intel 7265
Wifi-driver: iwlwifi
What i've tried
"iwconfig wlan0 power off" helps but I should do it every time my Laptop turns on. I tried to play with /etc/pm. Nothing helped. The only solution was adding
sleep 10
iwconfig wlan0 poweroff
exit 0
to /etc/rc.local. Now power management turns off, as I need, but only when I reboot/switch on laptop. If I turn my wifi on manually after suspend, I should also manually turn off power management.
I thought maybe 13.10 suspend kills wifi connection solution might help, I made a file wakenet.sh, but it doesn't work and it shouldn't as ubuntu 15.04 doesn't have nmcli nm, so it's impossible to use
nmcli nm sleep flase
At least I haven't found how to do it with new nmcli.
Maybe someone can help me at least in finding the proper alternative command instead of nmcli nm sleep false?
Sabine
  • 211
The best solution that worked for me (in Ubuntu 16.04LTS) is to change the value of wifi.powersave located in /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf from 3 (enabled) to 2 (disabled).
This effectively makes the effects of sudo iwconfig <interface> power off permanent.
Source: Power management for wireless unable to turn off in Xubunu 15.04 Vivid
jumblie
  • 251
there are a couple of options here:
How can I prevent iwconfig power management from being turned on?
The answer provided by Pierz worked for me:
Another approach is to add an explicit directive (wireless-power) to control power management in the /etc/network/interfaces configuration file (e.g. Disable it for wlan0 with DHCP):
auto wlan0
iface wlan0 inet dhcp
wireless-power off
I am using:
OS: Ubuntu 16.04.1 LTS  OS
image: ubuntu-16.04-preinstalled-server-armhf+raspi3.img
V Bota
  • 723
