For some reason I don't know, my wifi signal is very weak in Linux but is ok in Windows. The speed doesn't seem to be the issue, but something related with the strength of the wifi signal itself.
I am using ASUS N580VD-DM129T and I have iwlwifi driver for Intel(R) Dual Band Wireless AC 8265 in Linux Ubuntu 16.04 with Gnome. (I checked the name of the network card using dmesg | grep iwlwifi and looked for the output line "Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230"). I also tried running Ubuntu 18.04 and still had the same problem.
The output when I run dmesg | grep iwlwifi is the following:
[ 3.347436] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[ 3.386096] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-8265-33.ucode failed with error -2
[ 3.388185] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-8265-32.ucode failed with error -2
[ 3.397339] iwlwifi 0000:03:00.0: loaded firmware version 31.560484.0 op_mode iwlmvm
[ 3.412232] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 3.472665] iwlwifi 0000:03:00.0: base HW address: 88:b1:11:5e:93:f4
[ 3.550283] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
I thought it was weird that the loading fails twice before succeeding and wondered if that was the problem but it is not because of this. I installed iwlwifi-8265-ucode-22.361476.0.tgz available at https://wireless.wiki.kernel.org/en/users/Drivers/iwlwifi and it fails many times (33, 32, 31, until 23, and then work with version 22). So it is just searching for the available version.
I have also tried changing some options in the iwlwifi module as suggested here. But it didn't work. More precisely, I added options iwlwifi 11n_disable=1 swcrypto=1 to the end of the file /etc/modprobe.d/iwlwifi.conf. Leaving me with the following content in it:
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
This didn't work even when I ran $sudo modprobe -rv iwlwifi to remove the module and then $sudo modprobe -v iwlwifi to add it again.
EDIT 2: I also tried with Linux 17.10 and 18.04 and still had the same problem (weak signal compared to Windows).
EDIT 3: Trying what was suggested for realtek did not work either:
sudo modprobe -v iwlwifi ant_sel=2
https://connectwww.com/how-to-solve-realtek-rtl8723be-weak-wifi-signal-problem-in-ubuntu/4625/
EDIT 5: Trying to alter power management running
sudo sed -i 's/wifi.powersave = 3/wifi.powersave = 2/' /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
and then systemctl restart network-manager.service didn't work either.
This was suggested here and here. This link explains how to do it.
EDIT 4: When I run $ nmcli dev wifi list I get the following results:
* SSID MODE CHAN RATE SIGNAL BARS SECURITY
neuromancer Infra 11 54 Mbit/s 59 ▂▄▆_ WPA2
* waffles Infra 11 54 Mbit/s 48 ▂▄__ WPA2
Stephens_iMac Infra 11 54 Mbit/s 47 ▂▄__ WPA2
eduroam Infra 11 54 Mbit/s 45 ▂▄__ WPA2 802.1X
mac-sfg003 Infra 11 54 Mbit/s 42 ▂▄__
Crumpet Infra 11 54 Mbit/s 37 ▂▄__
Neuromancer is actually 2.5 meters from me and still is not full strength. (Note that EDIT 4 and EDIT 1 were run in different days, hence the different networks found)
EDIT 1:
Running $ sudo iwlist scan gives me the following output
lo Interface doesn't support scanning.
enp4s0 Interface doesn't support scanning.
wlp3s0 Scan completed :
Cell 01 - Address: 58:97:1E:72:D0:A1
Channel:1
Frequency:2.412 GHz (Channel 1)
Quality=46/70 Signal level=-64 dBm
Encryption key:on
ESSID:"eduroam"
Bit Rates:12 Mb/s; 18 Mb/s; 24 Mb/s; 36 Mb/s; 48 Mb/s
54 Mb/s
Mode:Master
Extra:tsf=00000078646f81d9
Extra: Last beacon: 4328ms ago
IE: Unknown: 0007656475726F616D
IE: Unknown: 01061824B048606C
IE: Unknown: 030101
IE: Unknown: 050700010900200000
IE: Unknown: 0706474220010D14
IE: Unknown: 0B051B006F093D
IE: Unknown: 200100
IE: Unknown: 2A0100
IE: Unknown: 2D1A2C181BFFFF000000000000000000000000000000000000000000
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : 802.1x
IE: Unknown: 3603E21600
IE: Unknown: 3D1601000700000000000000000000000000000000000000
IE: Unknown: 460573C0000000
IE: Unknown: 7F06001000000140
IE: Unknown: 851E27008F000F00FF035900636E63622D6C61625F617265615F6C001B000036
IE: Unknown: 9606004096001100
IE: Unknown: DD180050F2020101800003A44F0027A44F004243800072324100
IE: Unknown: DD06004096010104
IE: Unknown: DD050040960305
IE: Unknown: DD050040960B69
IE: Unknown: DD050040961409
IE: Unknown: DD16000B85F800015AA6AA0DD0F287C653371F84DC6C1608
Cell 02 - Address: 58:97:1E:72:D0:A0
Channel:1
Quality=47/70 Signal level=-63 dBm
Encryption key:off
ESSID:"OWL"
54 Mb/s
Mode:Master
Extra:tsf=0000007864711990
Extra: Last beacon: 4272ms ago
IE: Unknown: 00034F574C
IE: Unknown: 030101
IE: Unknown: 050F000108002000000000000000010000
IE: Unknown: 2A0100
IE: Unknown: DD050040960B09
IE: Unknown: DD050040961408
IE: Unknown: DD16000B85F800015AA6AA0D68445B38B7430C870C13ED10
Cell 03 - Address: 28:F0:76:49:02:32
Channel:11
Frequency:2.462 GHz (Channel 11)
Quality=40/70 Signal level=-70 dBm
Encryption key:on
ESSID:"Stephens_iMac"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=0000073adbc53791
Extra: Last beacon: 3732ms ago
IE: Unknown: 000D5374657068656E735F694D6163
IE: Unknown: 010882848B962430486C
IE: Unknown: 03010B
IE: Unknown: 2A0100
IE: Unknown: 32040C121860
Group Cipher : CCMP
Authentication Suites (1) : PSK
IE: Unknown: 2D1AAD4917FFFFFF0000000000000000000000000000000000000000
IE: Unknown: 3D160B000400000000000000000000000000000000000000
IE: Unknown: 7F080400000000000040
IE: Unknown: DD150017F209000108694D616331372C31010103010000
IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00
Cell 04 - Address: 58:97:1E:72:D0:AE
Channel:100
Frequency:5.5 GHz (Channel 100)
Quality=32/70 Signal level=-78 dBm
Encryption key:on
ESSID:"eduroam"
Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=00000352afa2581c
Extra: Last beacon: 2160ms ago
IE: Unknown: 0104B048606C
IE: Unknown: 050400010100
IE: Unknown: 070C47422024081764051784031E
IE: Unknown: 0B05010006093D
IE: Unknown: 200100
IE: Unknown: 2D1A6E181BFFFF000000000000000000000000000000000000000000
Group Cipher : CCMP
IE: Unknown: 3D1664050400000000000000000000000000000000000000
IE: Unknown: 851E03008F000F00FF035900636E63622D6C61625F617265615F6C0001000035
IE: Unknown: DD16000B85F800015AA6AA0F1A1ABC93574E004A621EB445
