I started by installing nvidia-current and nvidia-prime( I have no idea what this is. I read it online somewhere.Please tell me what it is :( ) and typed
sudo prime-select nvidia
and it gave me this
Error: alternatives are not set up properly
Error: nvidia mode can't be enabled
I googled for the error and based on Michael's advice here , I typed this( again I have no idea about it).
root@PapaGolf:~# sudo update-alternatives --config x86_64-linux-gnu_gl_conf
Result Of Command
and again tried to switch to nvidia by
root@PapaGolf:~# prime-select nvidia
Now I'm stuck with
Error: %s does not support PRIME power management
I googled for this error as well but couldn't get anywhere. Can anyone help?
Edit(Output of lspci -k | grep -EA2 'VGA|3D')
siera@PapaGolf:~$ lspci -k | grep -EA2 'VGA|3D'
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
    Subsystem: Dell Device 0662
    Kernel driver in use: i915
08:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] (rev a1)
    Subsystem: Dell GeForce 820M
    Kernel driver in use: nvidia
7_R3X
  • 1,191
  • 16
  • 31
You installed a wrong driver for your adapter.
nvidia-current is a package for legacy cards.
You need to remove it and install the correct one:
sudo apt-get purge nvidia*
sudo apt-get install nvidia-346 nvidia-prime
prime-select should work after reboot.
These commands will install Nvidia driver version 346 for Ubuntu 14.04 and 15.04.
For Ubuntu 15.10 the commands will install driver version 352.
Pilot6
  • 92,041
-1
use this in you terminal to install nvidia GPU sudo apt-get install bumblebee bumblebee-nvidia primus linux-headers-generic
