How can I modify the icon size of the side main unity panel on ubuntu 11.10? I've tried installing the compiz configuration (ccsm), but it doesn't work. Maybe I didnt installed compiz correctly. Thanks!
Asked
Active
Viewed 5,489 times
- Open the Ubuntu Software Center
- Search for compizconfig
- You should see the CompizConfig Settings Manager, install it.
- Press Alt+F2, type 'ccsm' and press Enter
- Once you have started CompizConfig Settings Manager, go to the Desktop category and click the Ubuntu Unity Plugin.
- Click the Experimental tab and change the value of 'Launcher icon size' setting.
Dimitrov
- 293
If you want to use CCSM you can find your answer here: How can I configure Unity?
The other option is to use gconf-editor (which you will have to install) and then go to:
apps > compiz-1 > plugins > unityshell > screen0 > options and looks for the 'icon_size' option. You can change it there as well using values from 32 - 64.
