You can rsync a mirror out. The benefit of this is you can update by just running the command again. The downside is that you're downloading everything... We're talking hundreds of gigabytes.
If you just want to cache updates between lan clients, a caching proxy is probably a better idea.
But assuming you want everything, let's start by creating a directory for our mirror.
mkdir -p ubuntu-mirror/dists
Then we can rsync into that. My version below just gets you the bits you need, rather than syncing every release. If you need -backports or -proposed, add them.
rsync -avz rsync://archive.ubuntu.com/ubuntu/dists/precise{,-security,-updates} ubuntu-mirror/dists/
There is a mirror at the University of Indonesia. They may have a better network and they're almost certainly going to have better latency than a London server for you. Substitute kambing.ui.ac.id in for archive.ubuntu.com. Everything is signed so as long as you aren't spuriously adding keys, you can trust mirrors.
Now that will take about a hundred years to run the first time. I've no idea, it really depends on the server, your connection and how big the repo actually is at that moment in time. It will almost certainly take so long that you'll be out of date immediately. Thankfully updating is faster.
If you find kambing.ui.ac.id has broken packages, use the central server.
But after that, you can just share it however you like and add it to your apt sources. Again, it's all using the standard keys, so you shouldn't need to add anything else except its location to your /etc/apt/sources.list.
