I recently upgraded to Oneiric and am having a strange printing problem. I can print just fine from Evince, Firefox, and presumably all programs that use the standard Gnome printing backend (as evidenced by the Gnome print dialog). But when I try to print from LibreOffice, the printer spits out the following error message followed by a blank page:
ERROR:
invalidfont
$definefont
STACK:
--nostringval--
/HJTLAV+TimesNewRomanPS-BoldMTFID777HGSet1
--nostringval--
--nostringval--
--nostringval--
13
The printer is a Samsung SCX-7423P using the generic PostScript driver. Everything worked fine under Natty.
Any ideas as to the cause of this problem, and more importantly, how to fix it?
EDIT:
Here's some additional information based on testing I did in response to @scottl's answer below:
  • I've tried three Oneiric boxes and only this one exhibits this problem. Unfortunately, it's a shared machine, so the impact is significant.
  • Exporting to PDF via either the toolbar button or the print to file option produces a file that Evince prints fine.
  • If I print to file and arrange for the filetype to be PostScript instead of PDF, I get the same error when printing on the affected machine using Evince. If I open the file on another machine and print it, everything is OK except that the font doesn't look quite right. I've posted an example PostScript file.
  • Even though the error output above mentions the font Times New Roman, the font isn't significant. The PostScript test was done using the font Ubuntu, and the error was the same except for the font name.
  • All testing was done using the same printer, as it's the only printer I have access to.
Try going to File -> Printer Settings -> Properties -> Device -> Printer Language and if it is set to PDF change it to PostScript.
To make this change stick:
  1. Make a document with this format and go to File -> Templates -> Save.
  2. In the new template type the name you want for it.
  3. In the list Category, select "My Documents" and click OK.
  4. Next choose File-Templates-Manage in the list templates, double-click the folder "My Templates".
  5. In the context menu, select the command "Set as default template" and close the dialog box.
The model is now used as the default template. Hope that works!
Jakehero
  • 116
http://bugs.ghostscript.com/show_bug.cgi?id=692240
It looks like this bug (actually caused by a badly pirated font), though that should be fixed in ghostscript 9.04 which is the version in oneiric.
Please upload an example postscript file illustrating the issue: http://paste.ubuntu.com/
Where did you get the font from, since Times New Roman is not installed in Ubuntu by default?
scottl
  • 2,588
