I am brand new to Ubuntu and the forums, and I know very little. So please keep all help simple. I can handle code, but no skipped steps please. Also, if one step needs prior knowledge, I won't know it. I got ubuntu on my Dell Inspiron 3520 model. I have 15.10. My wifi is out, and I don't know why. I have had Vista, Ubunt 14.10, 15.06, and 15.10, and all have thwarted me of wifi by no drivers. In the extra driver section, it says:
Broadcom Corporation: BCM43142 802.11b/g/n (Wireless 1704 802.22n + BT 4.0)
This device is not working.
Using Broadcom 802.11 Linux STA wireless driver source from bcmwl-kernel-source (proprietary)
I have tried to download it here, and failed. I have tried many methods, and none have worked. I tried all marked "Answered". I don't know what else to put in. If you need anything, tell me what. Ethernet works.
Eliah Kagan
  • 119,640
To fix this problem, make a dvd with the .iso with the latest version of ubuntu on it. Open the dvd. Click on the following: pool>restricted>b>bcmwl and drop the file on the desktop. Next go to pool>main>d>dkms and drop the file on the desktop. Both files should be .deb Next open the terminal(Control Alt T). Type in the command: cd ~/Desktop
and then: sudo dpkg --configure -a
if there is an error, type the command: lsof /var/lib/dpkg/lock and then: ps cax | grep PID
if it is running then type: kill PID
wait
kill -9 PID type this next: ps cax | grep PID then type: sudo rm /var/lib/dpkg/lock and finally: sudo dpkg --configure -a after typing that repeat: sudo dpkg --configure -a and finally type: sudo modprobe wl this will unlock your wifi. If it is still blocked by hardware switch, then type: sudo rfkill unblock wifi your wifi will be fixed. If not, look elsewhere for answers.
In my case after upgrading my Ubuntu 15.04 version to 15.10, It didn't recognize my wireless card. What I did was:
1) Run: lspci |grep Wireless (you will get your wireless driver chipset)
2) Download the firmware for my hardware from Intel support site and install it (# sudo cp iwlwifi-7260-15.ucode /lib/firmware/)
3) Download the drivers for my configuration from Broadcom support site, because when running: "sudo modprobe wl" y got the error message: "wl module not found". http://www.broadcom.com/support/?gid=1 (I picked: Linux® STA 64-bit driver --> hybrid-v35_64-nodebug-pcoem-6_30_223_271)
4) # make (to build the wl module) # sudo make install (install)
5) Reboot
Done!. So now I have my WiFi working properly again :)
Additional Steps Because a I have an Intel® Dual Band Wireless-AC 7260, it has some problems when enabling both bluetooth and WiFi, so I also had to do:
6) sudo vi /etc/modprobe.d/blacklist.conf add the line --> blacklist btusb
7) sudo vi /etc/modprobe.d/iwlwifi.conf
comment everything
