I am having huge problems with my PATH and LD_LIBRARY_PATH since I have installed new libraries. Generally speaking: I can't export permanently my PATH variables defined in my ~/.bashrc file. As example: when I boot and I type which mpiexec, I would expect the one linked to my mpich library defined in my~/.bashrc file, however, I get another one which is:
/usr/bin/mpiexec // vs expected output: /home/mpich/bin/mpiexec
So every time I need to manually type: PATH=/home/mpich/bin:$PATH ; export PATH, and I can't live with this as I have multiple libraries.
What I did:
Modify the bashrc with all my libraries using:
sudo nano ~/.bashrc, Output:export PATH=$PATH:/usr/local/cuda-10.1/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda-10.1/lib64
export CUDA_HOME=/usr/local/cuda-10.1
export PATH=$PATH:/snap/bin
export PATH=$PATH:/usr/bin
epxort PATH=$PATH:/bin
export PATH=$PATH:/home/mpich/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/mpich/lib
export PATH=$PATH:/home/opt/openmpi/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/opt/openmpi/lib
Edit the environment variables in
/etc/environmentOutput:
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/mpich/bin:/home/opt/openmpi/bin"
- type
$ source ~./bashrc - reboot
However, none of the above allow me to retrieve my PATH variables when booting.
So my question is : Where is the error relying and how could I export permanently my path variables defined in ~/.bashrc ? I am running on Ubuntu 18.04.
Any help would be more than appreciated as I have been spending hours on this problem. Thanks in advance
