W: Failed to fetch cdrom://Ubuntu 10.04.4 LTS _Lucid Lynx_ - Release i386 (20120214.2)/dists/lucid/main/binary-i386/Packages Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
W: Failed to fetch cdrom://Ubuntu 10.04.4 LTS _Lucid Lynx_ - Release i386 (20120214.2)/dists/lucid/restricted/binary-i386/Packages Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
E: Some index files failed to download. They have been ignored, or old ones used instead.
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Asked
Active
Viewed 168 times
-3
Mitch
- 109,787
Himanshu Rathor
- 1
- 1
this describes how you can fix the CD-ROM issue using the graphical interface: Failed to download repository information due to missing CDROM .
this is the command-line version:
edit your /etc/apt/sources.list. you will (probably) find lines similar to
deb cdrom:[Ubuntu 10.04 ...
in there. either add a # to the beginning of every such line:
# deb cdrom:[Ubuntu 10.04 ...
or delete those lines altogether.
$ sudo apt-get update
should then work.
also note that lucid is no longer supported. you will not get any security updates anymore. i suggest you upgrade to a current version such as 14.04 trusty.
if you still want to use lucid you can. but you will have to change all the entries in /etc/apt/sources.list pointing to http://old-releases.ubuntu.com/ubuntu/ :
change the lines in /etc/apt/sources.list from
deb http://archive.ubuntu.com/ubuntu/ ...
to
hiro protagonist
- 1,643
