I am new to Ubuntu and I have a couple of questions.
How can you sharpen text on Ubuntu?
How can you move applications from the task bar to the desktop ?
How can I make the shut down/ power off button more visible. Like being able to see it on the top bar than having to go to a menu
Thank You
Hello and welcome to Ubuntu! there are a few UI designs, but im guessing you have the ever popular Gnome
For text : Open a terminal and type
sudo apt-get install unity-tweak-tool gnome-tweak-tool
Once you have it under advanced settings, there is a "fonts section
To move applications to the desktop:
First off As a linux user, I recommend using the terminal and get used to not using the desktop! A better alternative is downloading Cairo-dock
If you must, and this goes against most linux users beliefs,
First copy your desired application's icon from the /usr/share/applications directory to Desktop,
sudo cp /usr/share/applications/filename.desktop ~/Desktop
Then change the permissions(give execute permission to the .desktop file) of copied .desktop file on the Desktop,
sudo chmod +x ~/Desktop/filename.desktop
Double click on the application icon to run it's corresponding application.
Power button:
Again most users use the terminal, and not buttons. Its traditional and faster. Learn these
sudo reboot (restart)
sudo shutdown -h now
sudo shutdown -P now
sudo poweroff (shutdown)
sudo halt -p
sudo init 0
I dont know if there is a way to change the top launcher, as that is part of the ubuntu file structure and cannot be changed.
Edziu Eames
  • 180
Assuming you have unity as you desktop environment, you install unity tweak-tool.
$ sudo apt-get install unity-tweak-tool
Once you install it, search for it in dash (dash opens once you press super/windows key) and click on it to open it.
In unity tweak-tool you can change your desktop themes, fonts etc.
To get shortcuts in your desktop, you can read this .
sps
  • 457
