I am using Ubuntu 14.04 kde plasma 5 - Dell xps laptop - graphics card nvidia GeForce GT 550m.
My two monitors won't work together! When I set the laptop screen as principal monitor, the external monitor is just blank. I can see the cursor, I can drag windows, but this is all I can do. And vice versa, the same thing happen when I set the external monitor as principal display!
I have tried several drivers (nouveau, proprietary...), I've tried to change settings in kde monitor settings and nvidia x server, I even tried to speak gently to my computer
Can you help me please?
Zanna
  • 72,312
I have the Nvidia 540M and I also faced some problems with Nouveau driver, but I figured out a solution quite simply after hours and days of search, when Nvidia finally released there driver on Ubuntu.
  • I suggest you to install the latest tested Nvidia Driver (346.96) by using the graphical interface (Drivers > Additional Drivers).
  • Do not forget to reboot after a proper installation and ensure that you actually run this driver.
  • Then, open NVIDIA X Server settings. On "Prime profiles" menu, check "Nvidia (Performance mode)".
  • You can finally perform some checks while pluging in in your monitor. It should appear on the Server settings menu, and can be easily configured.
emelyn
