trying to run the rails server i get this error:
/var/lib/gems/2.1.0/gems/execjs-2.6.0/lib/execjs/runtimes.rb:48:in `autodetect': Could not find a JavaScript runtime. See https://github.com/rails/execjs for a list of available runtimes. (ExecJS::RuntimeUnavailable)
    from /var/lib/gems/2.1.0/gems/execjs-2.6.0/lib/execjs.rb:5:in `<module:ExecJS>'
    from /var/lib/gems/2.1.0/gems/execjs-2.6.0/lib/execjs.rb:4:in `<top (required)>'
    from /var/lib/gems/2.1.0/gems/uglifier-2.7.2/lib/uglifier.rb:3:in `require'
    from /var/lib/gems/2.1.0/gems/uglifier-2.7.2/lib/uglifier.rb:3:in `<top (required)>'
    from /usr/lib/ruby/vendor_ruby/bundler/runtime.rb:76:in `require'
    from /usr/lib/ruby/vendor_ruby/bundler/runtime.rb:76:in `block (2 levels) in require'
    from /usr/lib/ruby/vendor_ruby/bundler/runtime.rb:72:in `each'
    from /usr/lib/ruby/vendor_ruby/bundler/runtime.rb:72:in `block in require'
    from /usr/lib/ruby/vendor_ruby/bundler/runtime.rb:61:in `each'
    from /usr/lib/ruby/vendor_ruby/bundler/runtime.rb:61:in `require'
    from /usr/lib/ruby/vendor_ruby/bundler.rb:133:in `require'
    from /home/acne/Documents/WWW/web/config/application.rb:7:in `<top (required)>'
    from /usr/lib/ruby/vendor_ruby/rails/commands/commands_tasks.rb:79:in `require'
    from /usr/lib/ruby/vendor_ruby/rails/commands/commands_tasks.rb:79:in `block in server'
    from /usr/lib/ruby/vendor_ruby/rails/commands/commands_tasks.rb:76:in `tap'
    from /usr/lib/ruby/vendor_ruby/rails/commands/commands_tasks.rb:76:in `server'
    from /usr/lib/ruby/vendor_ruby/rails/commands/commands_tasks.rb:40:in `run_command!'
    from /usr/lib/ruby/vendor_ruby/rails/commands.rb:17:in `<top (required)>'
    from bin/rails:4:in `require'
    from bin/rails:4:in `<main>'
How can i solve this? Thanks for your time !
Thomas Ward
  • 78,878
Either Install Node Js or install therubyracer gem
gem install therubyracer
Tachyons
  • 17,455
  1. Comment the gem "therubyracer".
  2. install nodejs.
  3. run the server again.
bummi
  • 394
cloxure
  • 101
