Finally, this is the time to throw Windows to the trash and start working with Ubuntu! Due to the fact that I had never did it before I would like to ask first in order to avoid further problems.
I have one physical hard-disk divided into 2 partitions C and D. Windows, naturally, installed on C. I would like to format C and install a fresh Ubuntu on it.
The question: Is partition D still will be accessible in Ubuntu, and if yes, how can I refer to it from within Ubuntu?
Morme
  • 23
In Ubuntu there are no drives: there are just disks and partitions and they all get mounted into the file system.
So, before you go ahead and install, boot the LiveDVD and use Try Ubuntu first! Then none of your hard disks will be touched and you can still use the full system and try out everything and it'll be obvious to you that all of your existing data can be found under these kinds of icons:
HD Icon
(Enlarged for better viewing)
If you decide after a while to wipe your Windows system partition (your "C:") have a look here on how to partition a single Windows-Ubuntu dual boot disk. Lots of the explanations in there will apply to your question.
Fabby
  • 35,017
Unlike windows, Ubuntu recognizes the NTFS file system of your D drive. After installing Ubuntu you will be able to mount that D drive by simply clicking it on its icon which will be shown on left hand side. Before installing it on your system it will be better if you first try using Ubuntu via live CD or a live pen drive, which you can easily create using lili(a windows software) and an ISO file for Ubuntu(Can be downloaded from official website of Ubuntu).
Ayushya
  • 241
