The screen resolution of my monitor is 1920x1080 (since it could run at 1080p in Windows 7), but however it runs at 1024x768 in my Ubuntu 12.04.
The output for lspci | grep -i vga is
00:02.0 VGA compatible controller: Intel Corporation Device 1912 (rev 06)
and the output for lshw -C video is
*-display UNCLAIMED
description: VGA compatible controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list
configuration: latency=0
resources: memory:f6000000-f6ffffff memory:e0000000-efffffff ioport:f000(size=64)
I have Ubuntu 12.04 running on the system. I have tried a variety of methods. I have tried using xrandr as given in Failed to get size of gamma for output default when trying to add new screen resolution and whn I try to set resolution in displays I get the following two error messages:
required virtual size does not fit available size: requested=(1920, 1080), minimum=(1024, 768), maximum=(1024, 768)
GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._gnome_2drr_2derror_2dquark.Code3: required virtual size does not fit available size: requested=(1920, 1080), minimum=(1024, 768), maximum=(1024, 768)
I tried debugging it but with no success.
I also came across that Intel has removed support for Ubuntu 12.04 and is that why I can't settle on any solution? I would like to try manually installing the drivers but I am clueless which one to go after.
I have also tried using nomodeset by updating the grub, but no use. Can anyone suggest something?
