I've found a bazillion references to get a list of the installed packages, but how can I print a single list of all known packages with their "package state" (not-installed, installed, half-installed etc. as defined by dpkg) in a shell, ideally like this:
awk   not-installed
bash  installed
cc    half-installed
dpkg --get-selections and dpkg --list only lists installed packages.
dpkg --get-selections '.' does not work.
apt-cache dump does not print whether packages are installed, and also prints a lot of irrelevant stuff.
I'm using Travis CI, which is running Ubuntu 12.04 LTS Server Edition 64 bit with for example dpkg-query 1.16.1.2.
l0b0
  • 9,271
You want dpkg-query;
For dpkg-query >= 1.17.11:
dpkg-query -f '${Package}\t${db:Status-Status}\n' -W '*'
For dpkg-query < 1.17.11:
dpkg-query -f '${Package} ${Status}\n' -W '*' | awk '{print $1"\t"$4}'
#1:
  • -f '${Package}\t${db:Status-Status}\n': When used with the -W option, specifies the format of the output (see man dpkg-query for other options);
  • -W '*': lists all the packages matching the pattern *;
#2:
  • -f '${Package} ${Status}\n': When used with the -W option, specifies the format of the output (see man dpkg-query for other options);
  • awk '{print $1"\t"$4}': prints only the first and fourth field;
In this case it seems like you want to list the status word, so I picked the db:Status-Status virtual field; here are the other virtual fields related to the package status:
              db:Status-Abbrev
                     It contains the abbreviated package status, such as  "ii"
                     (since dpkg 1.16.2).
              db:Status-Want
                     It contains the package wanted status, part of the Status
                     field (since dpkg 1.17.11).
              db:Status-Status
                     It contains the package status word, part of  the  Status
              db:Status-Eflag
                     It  contains  the  package status error flag, part of the
                     Status field (since dpkg 1.17.11).
user@user-X550CL ~/tmp % dpkg-query -f '${Package}\t${db:status-status}\n' -W '*' | head
aalib1  not-installed
account-plugin-aim  installed
account-plugin-empathy  not-installed
account-plugin-facebook installed
account-plugin-flickr   installed
account-plugin-foursquare   not-installed
account-plugin-gadugadu not-installed
account-plugin-generic-oauth    not-installed
account-plugin-google   installed
account-plugin-groupwise    not-installed
kos
  • 41,268
dpkg-query -l '*'
will show you all the installed, uninstalled and half installed packages. Just grep on the package you want to filter.
infoclogged
  • 541
  • 18
