I want to have a list of all packages that are installed on my server, but the command
dpkg --get-selections > ~/Package.list
doesn't do anything! When I execute it there is no file called "package.list" in the root folder.
You have to run the same command (there's no need to run it as root)
dpkg --get-selections > ~/InstalledPackages.list
Then you can
cat ~/InstalledPackages.list
to see the content.
Now, if you are not sure how's ~ been processed, you can
cd ~
pwd
And that's it.
Use dpkg-query, this command is precisely intended to what you need: request on packages data‑base. A quick man dpkg-query will tell you more, however, you may try dpkg-query --list or dpkg-query -- show.
What's with these answers lol all this question is asking is a simple dpkg output list,
dpkg --list | less
dpkg -l | more
dpkg-query -l | tail
dpkg-query --list | head
diff <(ps aux| grep x) <(pgrep x)
apt-file list "package"
You said you've looked in the root folder, but with the "~" you are clearly pointing to the home folder. The root would be /Package.list, or -/Package.list. Check in the home folder.
EDIT: As I can see now, even though my answer was correct, it might have been unclear to a fresh user. I'm sorry for introducing additional confusion. @0R10N thanks for good example :)
If you would like to get the versions of some installed packages, you can pipe commands like this:
dpkg --get-selections | awk '/php/{print $1}' | xargs dpkg-query --show $1
your output would look like the following:
libapache2-mod-php5 5.3.2-1ubuntu4.29
php5-cli 5.3.2-1ubuntu4.29
php5-common 5.3.2-1ubuntu4.29
php5-gd 5.3.2-1ubuntu4.29
php5-mcrypt 5.3.2-0ubuntu1
php5-mysql 5.3.2-1ubuntu4.29
php5-xsl 5.3.2-1ubuntu4.29
phpmyadmin 4:3.3.2-1ubuntu1
