13
Using the command-line, I want to create a log file with today's date in the name (for example, today is 05/17/2011, so the filename would have to be log051711).
I know how to create the file (touch filename), but I don't know how to get today's date. I have looked at the manual for date, but it seems that I can't really format its output?
Any help would be appreciated.
Melebius
  • 11,750
Louis B.
  • 245
5 Answers5
14
You can format the output using the '+FORMAT' parameter, e.g.
touch "log$(date +'%m%d%y')"
See the manpage for what sequences you can use in FORMAT.
Running the command
echo "myfilename-"`date +"%d-%m-%Y"`
gives this as the output:
myfilename-21-02-2014
Eliah Kagan
  • 119,640
One of the possible soultions:
date +log%y%m%d | xargs touch
creates log111017
Sergey
  • 44,353
I'm sure somebody else has a better way to do this but assuming you want month-day-year this should work:
touch log`date +%m%d%y`
and you can reorder the %m, %d, %Y to reflect the ordering you want. The man page for date tells you more about additional formats.
Dason
  • 858
Python can do this job as well. The small script for that would be the following:
#!/usr/bin/env python
import time,os
date=time.gmtime()
month = str(date.tm_mon).zfill(2)
day=str(date.tm_mday).zfill(2)
year=str(date.tm_year)[-2:]
fname = 'log' + month + day + year
with open(fname,'a') as f:
    os.utime(fname,None)
The idea here is simple: we use time.gmtime() to get current date, extract specific fields from the structure it returns, convert appropriate fields to strings, and create filename with the resulting name.
Test run:
$ ls
touch_log_file.py*
$ ./touch_log_file.py
$ ls
log010317  touch_log_file.py*
At the moment of writing it is January 3rd , 2017. Thus the resulting filename is appropriately month,day,year - log010317
