I have an ASUS ROG G750JS machine, in which I installed Ubuntu 14.04.3 LTS. I had two problems with the installation:
  1. The system froze when I asked it to reboot or shutdown. I solved it by adding the line GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset" to the /etc/default/grub file.
  2. It didn't detect wifi networks. I managed to make it detect my home's network by following the most upvoted answer in this question: Installing Broadcom Wireless Drivers
However, the connection is very, very slow. Not knowing how to solve this problem, I decided to try to untoggle the wifi with modprobe -r wl and toggle it again with modprobe wl. But when I do it, it never connects again, and keeps asking for the network's password until it times out.
Can anyone help me with this problem?
Edit
The output of lspci -nnk | grep 0280 -A2, as requested:
03:00.0 Network controller [0280]: Broadcom Corporation BCM4352 802.11ac
Wireless Network Adapter [14e4:43b1] (rev 03)
    Subsystem: AzureWave Device [1a3b:2123]
    Kernel driver in use: wl
Actually, on further inspection, this appears to be a known bug and there appears to be a work-around available. I absolutely have not tried this.
WORKAROUND: 6_30_223_95 driver in http://people.canonical.com/~ypwong/drivers/broadcom/ , install an old version: https://launchpad.net/ubuntu/saucy/amd64/bcmwl-kernel-source/6.30.223.30+bdcom-0ubuntu3 (found at http://gaspuu.blogspot.no/2014/05/dell-precision-m4800-with-ubuntu-linux.html), or simply replace the wifi module with another one with better driver support (if laptop has no whitelist for modules).
Source: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1173761
KGIII
  • 4,101
Verify that Hardware Virtualization is enabled in your BIOS, especially the virtual MMU thing.
Otherwise 32bit drivers and its host libs are all not going to work.
Byte Commander
  • 110,243
TardisGuy
  • 367
