12
I was working with the shell, and by mistake I autocompleted with tab after writing _e, which resulted in _expand.
What does this command do? I couldn't find an explanation online, the only references I could find here on Ask Ubuntu were:
But they don't answer my question. Instead, they open up more questions of the same kind about commands like _complete, _complete_as_root, etc.
0x5C91
  • 221
You can find out what _expand does, when typing
$ type _expand
_expand is a function
_expand ()
    if [[ "$cur" == \~*/* ]]; then
        eval cur=$cur;
    else
        if [[ "$cur" == \~* ]]; then
            cur=${cur#\~};
            COMPREPLY=($( compgen -P '~' -u "$cur" ));
            [ ${#COMPREPLY[@]} -eq 1 ] && eval COMPREPLY[0]=${COMPREPLY[0]};
            return ${#COMPREPLY[@]};
        fi;
    fi
This is a function in the bash completion mechanism. It expands tildes (~) in pathnames. In /etc/bash_completion is a comment about the function:
# Expand ~username type directory specifications.  We want to expand
# ~foo/... to /home/foo/... to avoid problems when $cur starting with
# a tilde is fed to commands and ending up quoted instead of expanded.
Try it in a terminal, type:
~<tab><tab>
It will expand to the usernames, for example
~usera     ~userb     ~userc
David Foerster
  • 36,890
  • 56
  • 97
  • 151
chaos
  • 28,186
