For example, if I type in "apt-"and press tab,I can find "apt-get" below.But if I type in "get", "apt-get" cannot appear. How can I do to match not only from the beginning?
Asked
Active
Viewed 584 times
As far as I know, it is not possible to search sub strings of all possible commands at a time.
You do though have the option of searching for sub strings of previously typed commands by using Ctrl+R and then typing your sub string. You can press Ctrl+R again to cycle through the previously typed commands containing this sub string
Zilvador
- 417
zsh might be able to get you halfway there:
For me, zsh seems to prefer prefix completions (file<tab> will get me file filefrag file-roller, -file<tab> will get me apt-file desktop-file-install ecryptfs-rewrite-file grub-file ...). I don't understand the completion system well enough to make zsh do substring matching even if prefix matching works. My completion options:
# The following lines were added by compinstall
zstyle ':completion:*' completer _expand _complete _ignored
zstyle ':completion:*' list-suffixes true
zstyle ':completion:*' matcher-list '' 'r:|[._-]=** r:|=**' 'l:|=* r:|=*' 'm:{[:lower:][:upper:]}={[:upper:][:lower:]}'
zstyle ':completion:*' squeeze-slashes true
autoload -Uz compinit
compinit
# End of lines added by compinstall
muru
- 207,228
