What causes this error when sudo apt-get update is issued?
W: GPG error: http://download.virtualbox.org trusty InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 54422A4B98AB5139
Sequence of events:
Install 14.04 (trusty), install VirtualBox from Ubuntu Software Centre and find it does not work, un-install VirtualBox using Ubuntu Software Centre, install from virtualbox.org using the Debian instructions at the link, issue apt-get update.
virtualbox.org, Instructions for Debian
Edit: There has been a response that suggests that this question is answered at a certain link. I read the answers at the link. This question is different. At the link we see how to resolve the error. This question is different because it asks for the cause. It does not ask for a resolution. This is my response to the link above about the "easiest way to resolve". I will check the comments and revise this edit if necessary.
H2ONaCl
  • 10,039
Whenever we add a repository for installing packages we also need a GPG key used by apt to authenticate packages for security reasons.
When adding a Launchpad hosted PPA this key will automatically be downloaded to use. So we do not have to do anything in addition.
This is different when adding an external repository such as the Oracle repository for Virtual Box. We then have to manually download and add the signing key. To do this the following steps are involved:
  • add the repository to our sources
  • download the GPG key
  • add this key for authentication
  • update our apt cache
  • install the desired software package
There are many different ways to achieve this, from command line or with graphical tools which I will not further elaborate here.
For adding the key there is a single-line command from the Virtual Box download page which always had worked for me:
wget -q https://www.virtualbox.org/download/oracle_vbox.asc -O- | sudo apt-key add -
Takkat
  • 144,580
The problem is that the command provided by the virtualbox website suggests adding the key using a command that simply will not work and also doesn't provide any error as to why.
Running the commands individually instead of in their piped form revealed there is what appears to be a DNS problem with wget. Here's the error I received:
user@computer:~$ wget https://www.virtualbox.org/download/oracle_vbox.asc
--2015-09-26 21:11:57--  https://www.virtualbox.org/download/oracle_vbox.asc
Resolving www.virtualbox.org (www.virtualbox.org)... failed: Temporary failure in name resolution.
wget: unable to resolve host address ‘www.virtualbox.org’
Use aria2 instead (aria2 is way more advanced and reliable than wget anyhow but that's another discussion).
Because there is a DNS problem when using wget, I suggest using aria2 to download the key instead.
First, install aria2:
sudo apt-get install aria2
Then, run the following command to add the key:
aria2c https://www.virtualbox.org/download/oracle_vbox.asc; sudo apt-key add oracle_vbox.asc; rm oracle_vbox.asc
Finally, you should be able to run the following without issue:
sudo apt-get update
The following is an example of what you should see if adding the key is successful. Most importantly, it should say (OK):download completed. and OK on the last two lines respectively.
Download Results:
gid   |stat|avg speed  |path/URI
cff9ac|OK  |    33KiB/s|/home/H2ONaCl/oracle_vbox.asc.1
Status Legend:
OK
Please post any errors.
mchid
  • 44,904
  • 102
  • 162
It was probably because the part of the instructions at virtualbox.org that instructed to
was not performed.
There was no intention to use HTTPS so that command was skipped. VirtualBox installed successfully without use of apt-key add. It was probably a less secure way to install.
mchid
  • 44,904
  • 102
  • 162
H2ONaCl
  • 10,039
