10
I am a big fan of Mate desktop. Simple and very functional.
But there one thing I'd address to the mate desktop: its screenshot utility is too poor.
The very single feature I miss there is being able to take a screenshot of only a part of the screen. It is apparently available with gnome-screenshot as from this post: What screenshot tools are available?
Is there any way I could replace mate-screenshot to gnome-screenshot?
I tried sudo apt-get install gnome-screenshot but then if I try to launch it, I have
▶ gnome-screenshot
** Message: Unable to use GNOME Shell's builtin screenshot interface, resorting to fallback X11.
Besides, I really need the shortcuts (the whole point is to achieve it in two clicks), so even if I get it working, I'll also need this.
FYI, I was using shutter earlier, but removed it because it was lacking the desktop shortcuts and sometimes very buggy (need to hard shutdown the system).
I resolved the same issue by adding the --interactive option
gnome-screenshot --interactive
N0rbert
  • 103,263
tmcp
  • 349
Actually, mate-screenshot does have the utility you want, (see man mate-screenshot) so there's no need to install an extra package. In a terminal, you can use the -a flag
mate-screenshot -a
This turns the pointer into a cross-hair and you can click and drag to select the area you want to grab.
You can set a custom shortcut for it (for example shift+prt sc like gnome-screenshot) in:
System > Preferences > Hardware > Keyboard Shortcuts
click the + Add button to add a custom one.
You may well find that using the command mate-screenshot -a in the keyboard shortcut does not work, in which case you need to modify the command to call bash and set DISPLAY... First check the variable in a terminal:
echo $DISPLAY
and take note of the output. For me it's :0.0
Then use this command in the shortcut setting:
bash -c "DISPLAY=:0.0 mate-screenshot -a"
Replacing :0.0 to match the output from echo $DISPLAY
Zanna
  • 72,312
As @Zanna sais, mate-screenshot does have the availability of doing area screenshots.
But there is a well known bug (https://github.com/mate-desktop/mate-utils/issues/37) which makes the command with this option fail.
As mentioned in the comments, the solution is to slighly delay the command:
#!/bin/bash
sleep 1
exec /usr/bin/mate-screenshot $@
within eg. /usr/local/bin/mate-screenshot and use it instead.
It changed my life, I keep using this feature now!
