62
Not a COM32R image
boot
This is the message that the console infinitely spits out when I try to install Ubuntu 10.04 from a USB. I created the USB using StartupDiskCreator in 11.04.
What is the reason for this behavior? What do I do to set it right?
I have carefully followed the steps listed in the Ubuntu Install from USB page.
Zanna
  • 72,312
5 Answers5
118
A quick/dirty way to solve this issue is to press TAB, the computer will provide a text menu with your options, i.e. live live-install test etc.
Now just type the option you want, i.e. live Enter. This will boot it as a Live CD [sic], and then continue installation from there.
Insperatus
  • 5,093
10
I just ran into the exact same problem. I followed the answer posted by 'Lelouch Lamperouge' and can make one small change, I did not have the 'live' command or option to boot from, but instead where it said boot: I typed install and hit enter
This started the installer normally and I did not have any further problems.
I'm not sure why this comes up, I can imagine it is a problem with how the bootloader is installed (but I could be wrong). Either way this worked for me. Good Luck!
rlemon
  • 1,861
  • 19
  • 38
I had the same problem when making a boot image on windows for an ovm 3.03 install using Unetbootin. I switched to Universal-USB-Installer-1.8.9.0 and scrolled all the way to the bottom of the linux distro pulldown and selected the "old syslinux" option. Worked like a charm.
Cnj
I'm not an expert in any way but I do make USB boot drives for my company and what I use is Unetbootin.
The reason I use Unetbootin rather than startup disk creator is that I have noticed that certain computers have issues with startup disk creator's way of preparing the USB drive.
Zanna
  • 72,312
-1
So I have no idea why this is error occurs but I can add something to this:
I created a boot stick to install Ubuntu on a newer and a pretty old notebook.
On the newer one I could choose to boot in UEFI mode. This did work!
The older one however does not have UEFI so I had to follow the above instructions.
So either the boot stick got created in a way that makes it only work on UEFI properly, or UEFI can handle the issue by itself.
Zanna
  • 72,312
