Can I use my existing Windows partitions to install Ubuntu?
I don't want to loose files and I also don't want to change the partitions.
Thanks in advance.
cl-netbox
  • 31,491
Simply install Ubuntu following this guide.
At step Installation Type select Install Ubuntu alongside Windows.
This way partitioning will be done automatically by the Ubuntu installer and none are your Windows data/files will be lost.
Before doing anything : Make sure you do a backup !
The installer's behavior is not always predictable. Sometimes it considers an existing partition to be worth keeping, sometimes not. And this option will only be available, if there is either unpartitioned space on the disk, or there are other partitions besides the Windows system partition (this may also accidentally be your data partition!), which then will probably get overwritten. - Byte Commander
hg8
  • 13,582
