When I click on a magnet link Chrome/Chromium open Transmission ...
I'm would like to change this to use Tixati
Postadelmaga
  • 5,759
From this question
xdg-open's config via gconf-editor didn't do anything to resolve the issue: since as of Natty the file-open functionality is handled by gvfs-open, which doesn't use gconf settings. Rather, gvfs-open looks at the ".desktop" files
So here some general instruction, they should work for every client ( just wisely change tixati with what is required by you )
1. Check the tixati.desktop file
Actually tixati.desktop looks fine so you can skip this step
sudo gedit /usr/share/applications/tixati.desktop
Here we need to check that:
  • Exec=tixati %U contains the %U
  • MimeType contains at least these 2 entry MimeType=application/x-bittorrent;x-scheme-handler/magnet;
If not fix it and the run sudo update-desktop-database
2. set default application for Magnet
I suggest to uninstall transmission anyway this command should set tixati as default:
xdg-mime default tixati.desktop x-scheme-handler/magnet
Postadelmaga
  • 5,759
