This has been asked tons of times, that's why I've tried out a couple of solutions and since none of the stuff worked, decided to ask for help here (as a last/desperate resort).
I own a Dell Inspiron 15R and have been using Ubuntu 14.04 for a couple of weeks. Fairly new to this world, but was determined to get away from Windows. So I'm running this baby with two partitions
  1. Ubuntu 14.04
  2. Windows 8.1
I've disabled ipv6, edited nsswitch and conf files
E.g. newly added in sysctl.conf
#disable ipv6
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
net.core.rmem_default = 524288
net.core.rmem_max = 524288
net.core.wmem_default = 524288
net.core.wmem_max = 524288
net.ipv4.tcp_wmem = 4096 87380 524288
net.ipv4.tcp_rmem = 4096 87380 524288
net.ipv4.tcp_mem = 524288 524288 524288
net.ipv4.tcp_rfc1337 = 1
net.ipv4.ip_no_pmtu_disc = 0
net.ipv4.tcp_sack = 1
net.ipv4.tcp_fack = 1
net.ipv4.tcp_window_scaling = 1
net.ipv4.tcp_timestamps = 1
net.ipv4.tcp_ecn = 0
net.ipv4.route.flush = 1
lspci -knn | grep Net -A2
02:00.0 Network controller [0280]: Intel Corporation Wireless 7260 [8086:08b1] (rev 73)
    Subsystem: Intel Corporation Wireless-N 7260 [8086:4462]
    Kernel driver in use: iwlwifi
Here's the speed test.
Please help me, I'm at the end of my tether. True story. :'(
I tried it and worked fine for me. Try adding OpenDNS server to your IPv4 setting
208.67.222.222 and 208.67.220.220
Open your terminal and then type iwconfig If you are getting this output :-
ppp0 no wireless extensions.
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=19 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:on
Then try disabling your power management on Wi-Fi. This will increase your continuity in speed but will consume your battery 2% to 3% faster.
To disable this
sudo gedit /etc/pm/power.d/wireless
Copy and paste below into the empty file and save it.
#!/bin/sh
/sbin/iwconfig wlan0 power off
Now you need to change the permission
sudo chmod 755 /etc/pm/power.d/wireless
Now restart your system. Hope this works for you.
