16
According to How can PPAs be removed? there are mainly 3 methods to get rid of a PPA:
  • Use the add-apt-repository command:
    sudo add-apt-repository --remove ppa:???/???
  • Manually remove the .list file:
    sudo rm /etc/apt/sources.list.d/????.list
  • Use additional tools like e.g. ppa-purge... (not topic of this question)
I am curious what the difference between the first and second option is, i.e. is there anything more that add-apt-repository --remove does, compared to just deleting the .list file?
One example I could think of would be GPG keys that were installed together with the PPA. Will add-apt-repository handle and remove them in contrast to just rm-ing the .list file?
Please note that neither removing GPG keys nor using ppa-purge is the topic of this question!
Byte Commander
  • 110,243
Both commands remove the PPA, but there is one basic difference:
This command will only delete content of .list file. It will not remove the file itself.
Once you run this command, it will completely remove the PPA file.
However, in my opinion, it's better to use :
sudo rm /etc/apt/sources.list.d/????.list*
I generally use the last command with the trailing asterisk (*), because whenever we add any repository it will create two files under /etc/apt/sources.list.d/. First one is the .list file and second one is a backup of that, having the extension .list.save.
same case with command sudo apt-key del ???? and sudo rm /etc/apt/trusted.gpg.d/file.gpg. whenever we add keys two file created under /etc/apt/trusted.gpg.d/ file.gpg and file.gpg~ when you run command
one file file.gpg will be deleted and second one will remain file.gpg~ as it is . However, in my opinion, it's better to use :
sudo rm /etc/apt/trusted.gpg.d/file.gpg*
muru
  • 207,228
pl_rock
  • 11,715
No, apt-add-repository will not handle the GPG keys, so if you want to remove the keys as well, use rm /etc/apt/sources.list.d/???.list and then the GPG Keys from /etc/apt/trusted.gpg.d/
David
  • 3,487
