I've been searching here and have a very similar problem to another post at (How do I free up more space in /boot?)
The problem I'm getting is when I try the solution. For example: sudo apt-get purge linux-image-2.6.38-11
I get:
Reading package lists... Done
Building dependency tree
Note, selecting 'linux-image-2.6.38-11-server' for regex 'linux-image-2.6.38-11'
You might want to run 'apt-get -f install' to correct these:
linux-image-server : Depends: linux-image-3.2.0-36-generic but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
This is on an older Ubuntu 12.0.4.1 LTS server I've inherited. uname -a reports
3.2.0-35-generic #55-Ubuntu SMP
Am I left with having to resize the partition? ls /boot reports the following:
abi-2.6.38-11-server lost+found
abi-2.6.38-12-server memtest86+.bin
abi-2.6.38-13-server memtest86+_multiboot.bin
abi-2.6.38-14-server System.map-2.6.38-11-server
abi-2.6.38-15-server System.map-2.6.38-12-server
abi-2.6.38-16-server System.map-2.6.38-13-server
abi-2.6.38-8-server System.map-2.6.38-14-server
abi-3.0.0-26-server System.map-2.6.38-15-server
abi-3.2.0-34-generic System.map-2.6.38-16-server
abi-3.2.0-35-generic System.map-2.6.38-8-server
config-2.6.38-11-server System.map-3.0.0-26-server
config-2.6.38-12-server System.map-3.2.0-34-generic
config-2.6.38-13-server System.map-3.2.0-35-generic
config-2.6.38-14-server vmcoreinfo-2.6.38-11-server
config-2.6.38-15-server vmcoreinfo-2.6.38-12-server
config-2.6.38-16-server vmcoreinfo-2.6.38-13-server
config-2.6.38-8-server vmcoreinfo-2.6.38-14-server
config-3.0.0-26-server vmcoreinfo-2.6.38-15-server
config-3.2.0-34-generic vmcoreinfo-2.6.38-16-server
config-3.2.0-35-generic vmcoreinfo-2.6.38-8-server
grub vmcoreinfo-3.0.0-26-server
initrd.img-2.6.38-11-server vmlinuz-2.6.38-11-server
initrd.img-2.6.38-12-server vmlinuz-2.6.38-12-server
initrd.img-2.6.38-13-server vmlinuz-2.6.38-13-server
initrd.img-2.6.38-14-server vmlinuz-2.6.38-14-server
initrd.img-2.6.38-15-server vmlinuz-2.6.38-15-server
initrd.img-2.6.38-16-server vmlinuz-2.6.38-16-server
initrd.img-2.6.38-8-server vmlinuz-2.6.38-8-server
initrd.img-3.0.0-26-server vmlinuz-3.0.0-26-server
initrd.img-3.2.0-34-generic vmlinuz-3.2.0-34-generic
initrd.img-3.2.0-35-generic vmlinuz-3.2.0-35-generic
One poster mentioned they ended up using rm -f to remove as the above method didn't work, but this was also not recommended. Thanks in advance, Sir_Timbit
An update: I ended up backing up all the old 2.6.x kernels and deleted them. This did get rid of the "/boot is using 98%" warning. However, I then tried to do a
apt-get -f install
It chugged along but eventually errored out with the following:
update-initramfs: Generating /boot/initrd.img-3.2.0-90-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.2.0-90-generic /boot/vmlinuz-3.2.0-90-generic
Generating grub.cfg ...
Found linux image: /boot/vmlinuz-3.2.0-90-generic
Found initrd image: /boot/initrd.img-3.2.0-90-generic
Found linux image: /boot/vmlinuz-3.2.0-35-generic
Found initrd image: /boot/initrd.img-3.2.0-35-generic
Found linux image: /boot/vmlinuz-3.2.0-34-generic
Found initrd image: /boot/initrd.img-3.2.0-34-generic
Found linux image: /boot/vmlinuz-3.0.0-26-server
Found initrd image: /boot/initrd.img-3.0.0-26-server
Found linux image: /boot/vmlinuz-2.6.38-16-server
Found initrd image: /boot/initrd.img-2.6.38-16-server
Found memtest86+ image: /memtest86+.bin
done
dpkg: dependency problems prevent configuration of linux-image-server:
linux-image-server depends on linux-image-3.2.0-36-generic; however:
Package linux-image-3.2.0-36-generic is not installed.
dpkg: error processing linux-image-server (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Setting up linux-headers-3.2.0-90 (3.2.0-90.128) ...
Setting up linux-headers-3.2.0-90-generic (3.2.0-90.128) ...
Examining /etc/kernel/header_postinst.d.
run-parts: executing /etc/kernel/header_postinst.d/dkms 3.2.0-90-generic /boot/vmlinuz-3.2.0-90-generic
Setting up linux-headers-server (3.2.0.36.43) ...
dpkg: dependency problems prevent configuration of linux-server:
linux-server depends on linux-image-server (= 3.2.0.36.43); however:
Package linux-image-server is not configured yet.
dpkg: error processing linux-server (--configure):
Setting up linux-libc-dev (3.2.0-36.57) ...
linux-image-server
linux-server
