I decided to teach to my students (10-13 years old) pc and software using a live USB distribution of edubuntu. I can't erase Windows XP becuase it used by other teachers and using a live USB is faster for me than installing dual boot partitioning and so on. But there is a problem. When the system is ready the students can go in nautilus and erase Windows files because they have permissions. What must I do? Can I change permission? Is the change permanent?
muru
  • 207,228
Since this would imply dropping sudo rights for the students anyway, a quick workaround could be this one:
  1. Boot from the Live USB
  2. Make sure all the partitions you don't want the student to access are mounted
  3. Open Terminal with Ctrl+Alt+T
  4. Change the ubuntu user's password: run passwd, hit Enter, type a password, type the password again and hit Enter
  5. Close the terminal: run exit
  6. Start the Guest user's session
This way being the partitions mounted in the ubuntu user's session there's no way for them to be mounted on the Guest user's session as well (unless by switching back to the ubuntu user's session in order to unmount them, which can't be done without knowing the password).
kos
  • 41,268
You can just unmount partitions that you don't want people to mess with. That would have additional pro of not tempting anybody to try to get there by just not showing any windows partition whatsoever.
  2. Open Terminal
  3. Find out windows partition by f.ex. mount | grep ntfs (if it's ntfs filesystem, or vfat, if it's fat32)
  4. sudo umount [mountpoint of windows filesystem] (it will probably be someting like /media/[something])
  5. Exit terminal
