11
I'm trying to backup my home directory (excluding a few folders). The backup is saved on a ~300 GB partition (called backups) of an internal drive, but not the same drive as the home directory. When I try to backup, everything goes OK until at some point Déjà Dup says there is no space left on "backups". The problem is that Déjà Dup only used ~20 GB at this point, so there is a ton of space left. I tried several times without luck.
Why is Déjà Dup saying this?
The size of my home directory, without the excluded folders, is 136 GB.
muru
  • 207,228
5 Answers5
13
So there are three possible places where Deja Dup might be out of space, and I don't think its error message tells you which. There is a bug filed about that.
  • You may have run out of space on the target partition (which it sounds like you didn't)
  • You may have run out of space in your home directory (~/.cache/deja-dup can get large)
  • You may have run out of space in /tmp
You can move the location of the cache-directory as follows (create a symlink to a new cache location)
mkdir /othervolume/.deja-dup-cache
mv ~/.cache/deja-dup/* /othervolume/.deja-dup-cache/
rmdir ~/.cache/deja-dup
ln -sf /othervolume/.deja-dup-cache ~/.cache/deja-dup
to change the location of the tmp-directory have a look at the following post: Deja Dup backup, change use of /tmp to another folder/location
Urs Honegger
  • 71
I had the same problem
I had >900Gb left on the partition, 13Gb left on the cache folder in ~ and /tmp contained only 13 Kb
I solved the problem just by rebooting
I am operating my root system on an SSD drive, and once read an article about swapping certain folders like /tmp, /var/log, and so on to RAM, which lowers your potential RAM space and the size of the /tmp folder. Exactly this swapping of my /tmp folder caused the no space left error in Deja Dup.
Here is what I did to my fstab back then (sorry, it's in German).
...and parts of the code to put in fstab:
tmpfs   /tmp    tmpfs   nosuid  0   0
So if you made the same changes to your fstab in order to improve performance, simply undo it like this:
# tmpfs /tmp    tmpfs   nosuid  0   0
Braiam
  • 69,112
You might try formatting your backup partition as NTFS.
I had exactly the same error when these two conditions came together:
  • the backup partition is formatted as FAT.
  • the backup included huge files such as virtual hard disc images for VirtualBox.
Formatting the backup partition as NTFS resolved the problem in my case.
user1251007
  • 1,131
