I am looking for a batch to make little commands in a terminal (for ubuntu) and save the answers in a data base in mysql in the same computer.
For example, I want to ask the temperature of the computer each hour, and save the answers in a data base already created. I do not if I should use php or just a batch to make a connection to the data base and save the information, but I do not know how to do neither of this posibilities.
Help please.
Bye.
This is easily done in Python. First, learn how to get your CPU's temperature here. Either use the sensors command or the cat /sys/class/thermal/thermal_zone0/temp to write the current temperature to a temporary file curr.temperature. You can do that seperately in a bash script or in the Python program itself, using:
from subprocess import call
call (["/path/to/script/get_temperature"], shell=False)
Then the Python code just needs to read the file curr.temperature and store the value in a MySQL table. I have not tested this code, but it should be something like this:
#!/usr/bin/python
import MySQLdb.cursors
with open('curr.temperature', 'r') as f:
    read_data = f.read()
db = MySQLdb.connect(db='databasename', host='localhost',
                     port=3306, user='MySQL-username', passwd='password',
                     cursorclass=MySQLdb.cursors.DictCursor)
cur = db.cursor()
cur.execute("INSERT INTO temperatures VALUES (now," + read_data + ")" )
Jos
  • 30,529
  • 89
  • 96
