With the script below, you can set the screen's brightness from 0.1 to 1.0, in 9 steps, on any system that "obeys" xrandr.
Just run it with either the argument "up" or "down" to increase/decrease the current brightness one step.
The script
#!/usr/bin/env python3
import subprocess
import sys
arg = sys.argv[1]
# get the data on screens and current brightness, parsed from xrandr --verbose
current = [l.split() for l in subprocess.check_output(["xrandr", "--verbose"]).decode("utf-8").splitlines()]
# find the name(s) of the screen(s)
screens = [l[l.index("connected")-1] for l in current if "connected" in l]
# find the current brightness
currset = (round(float([l for l in current if "Brightness:" in l][0][1])*10))/10
# create a range of brightness settings (0.1 to 1.0)
sets = [n/10 for n in list(range(11))][1:]
# get the current brightness -step
step = len([n for n in sets if currset >= n])
if arg == "up":
if currset < 1.0:
# calculte the first value higher than the current brightness (rounded on 0.1)
nextbright = (step+1)/10
if arg == "down":
if currset > 0.1:
# calculte the first value lower than the current brightness (rounded on 0.1)
nextbright = (step-1)/10
try:
for scr in screens:
# set the new brightness
subprocess.Popen(["xrandr", "--output", scr, "--brightness", str(nextbright)])
except NameError:
pass
How to use
- Copy the script into an empty file, save it as
set_brightness.py
Test- run it by the commands:
python3 /path/to/set_brightness.py up
and
python3 /path/to/set_brightness.py down
If all works fine, add both commands to shortcut keys: choose: System Settings > "Keyboard" > "Shortcuts" > "Custom Shortcuts". Click the "+" and add both commands above to two different shortcut keys.
Explanation
The explanation on the code is pretty much in the script :)
Notes
As it is, the scripts sets the brightness equally for both the "main" and possible additional screen(s).
